Created an irule below but it only seems to work for lowercase not uppercase. Do I have to add another line or can it be tweaked to catch anything? “coordinatororporttype”
when HTTP_REQUEST { if { [string tolower [HTTP::uri]] contains “/wls-wsat/coordinatorporttype” } { log local0. “matched URI [HTTP::uri]” drop } }
log local0. "URI is [HTTP::uri]"
if { [string tolower [HTTP::uri]] contains "/wls-wsat/coordinatorporttype" } {
log local0. "matched URI [HTTP::uri]"
drop
drop
if there are many clients, you may add client ip and probably port number to the log. so, it might be easier to find the problem request.
e.g.
log local0. "client is [IP::client_addr]:[TCP::client_port] URI is [HTTP::uri]"
log local0. "client is [IP::client_addr]:[TCP::client_port] matched URI [HTTP::uri]"
drop
e.g.
drop
I checked the ltm log files and I don’t see any corresponding info regarding the URI rule. I checked in statistics and it shows that Total Executions are rising. Is there another place that it would log to?
I found the logs. Didn’t give it enough time. I do have a question. I see that we are logging the client ip but for some reason it doesn’t up. Any thoughts?
