Assuming “example.com” DNS TTL is set to 60 seconds - will nginx re-resolve DNS after 60 seconds? Or does it only resolve the name on startup? I’m finding different info around the internet:
- it will re-resolve only in the commercial nginx plus
- it will re-resolve only in newer nginx releases; in older ones, one need to make some workarounds
- it will only resolve once on startup and never again
This blog post explains the various methods NGINX and NGINX Plus handles domain resolution - NGINX | F5. To summarize, you can configure NGINX to resolve hostnames regularly using these methods (credits to original blog post):
1. Setting the Domain Name in a Variable
resolver 10.0.0.2 valid=10s;
server {
location / {
set $backend_servers backends.example.com;
proxy_pass http://$backend_servers:8080;
directive to explicitly specify the name server (NGINX does not refer to /etc/resolv.conf as in the first two methods). By including the
valid
parameter to the
resolver
directive, you can tell NGINX to ignore the TTL and re‑resolve names at a specified frequency instead. Here we tell NGINX to re‑resolve names every 10 seconds.
Drawback is that because the upstream group is not used, specify the load‑balancing algorithm or other parameters to the server directive.
2. (NGINX Plus only) Using DNS A records
upstream backends {
zone backends 64k;
server backends.example.com:8080 resolve;
server {
location / {
proxy_pass http://backends;
By default, NGINX Plus honors the TTL, re‑resolving names when records expire. To have NGINX Plus instead re‑resolve names at a specified frequency, include the valid parameter to the resolver directive.
This gives the additional benefit of being able to configure additional settings for upstream servers via the server directive.
Do take a look at the blog post to see other methods available, such as via DNS SRV records which supports dynamic port numbers and weightings. Hope that helps.
- connection to local-server/_example/image.jpg will be passed to example.com/_example/image.jpg
- only DNS resolved at startup is used, even though nginx queries DNS for “example.com” from time to time
- connection to local-server/_example/image.jpg will be passed to example.com/_example/ - note the missing “image.jpg” when querying the upstream!
- DNS changes work
On 1, I don’t have knowledge of how the underlying code is written, but barring the periodic DNS requests, NGINX seems to be behaving as intended in terms of resolving the host with new value after restart/config reload.
one question regarding NGINX (not NGINX+) and setting DNS in a variable.
We are using this method (#1) but having the “set” directive in the server section instead of in the location section. We noticed that NGINX is not updating new IP address … even if we see DNS requests and responses with updated IP@ (this is happening using AWS ALB).
I can confirm that resolver not working when i did the same setup like above
server {
location / {
nginx v1.24.0 and v.1.25.2, both of them do not work. Seems like they going to take care nginx plus version too much and forget to fix this in the open source version.
