I have a question regarding BIG-IP’s communication with pool member servers. Is it accurate that the BIG-IP has no concept of the ‘hostname’ of the pool members and forwards traffic to pool members by IP alone? I have set up a serverssl profile that is configured to ‘Require’ Server Certificate and DROP untrusted and expired SSL certs presented by member servers. It all works except for ONE scenario: When a member server presents an SSL cert with a CN that matches the Authenticate Name on the server SSL profile but is the WRONG SSL cert for it.
e.g: The member hostname is foo.example.com; it is serving an SSL cert for CN bar.example.com. The server-ssl profile is set up with Authenticate Name bar.example.com. I would have expected the BIG-IP to DROP traffic to pool member foo.example.com but it doesn’t. The BIG-IP sees ‘bar.example.com’ for Authenticate Name in the serverssl profile, matches that to the ‘bar.example.com’ in the CN of the SSL cert presented by server and blesses the communication.
I’m running BIG-IP 11.5.1 HF10; is someone able to confirm that this is indeed how it works and maybe suggest what I could do to make the BIG-IP check pool member hostname.
Hi alokjhafb,
HTTP communication and the underlying TLS/SSL communication are completely distinct from each other.
The clientside connection may request (via Server Name Indication) a certificate for but then may request a page using the HOST-name of .
The F5 may establish a serverside SSL connection to a pool member and then check if a specific CNAME / DNS Name is present in the received certificate. But right after the the F5 can still forward requests for a completely different HOST-name.
This is an intended default behavior. But feel free to overwrite this behavior by using handcrafted iRules and/or LTM Policies to filter out requests for unknown HOST-names as well as selecting the right Pools and matching Server_SSL_Profiles based on the requested HOST-names.
Example iRule:
set low_host [string tolower [HTTP::host]]
if { $low_host eq "www.domain.net" } then {
pool "Pool_www.domain.net"
set server_ssl "/Common/SRV_SSL_www.domain.net"
} elseif { $low_host eq "www.domain.com" } then {
pool Pool_www.domain.com
set server_ssl "/Common/SRV_SSL_www.domain.com"
Unknown HOST-name requested
HTTP::respond 502 content "Bad Gateway: Unknown HOSTNAME requested" "Content-Type" "text/html" "Connection" "close"
TCP::close
when SERVER_CONNECTED {
SSL::profile $server_ssl
Cheers, Kai
