We are attempting to run a Docushare web scanner application through APM that requires NTLM authentication. The Application has to access a scanner on the local device using https://127.0.0.1:[port]/dcp/… The port number is not random, but there could be more than one.
I have tried to split tunnel the portal page and network access list. However none of these are working as the call for the https://127.0.0.1:[port]/dcp/… is created dynamically on the client through .js or .css variables that are passed to the client. All The F5 ever sees in the stream is the .js and .css code, not the variable names and values.
Since the F5 does not see the call from the client until the client attempts to make the call, it is rewriting the host to be https://f5-portal.net/f5-w-687…$$/dcp/* (example URL only) and dropping the https://127.0.0.1:[port]/dcp/*
Can anyone help me with how to make this work properly? All suggestions are welcome. BTW, redirect does not work as there are multiple ports that the local scanner could be listening on.
