I am trying to configure a two-way SSL authentication but am getting errors stating handshake failure. I need to know if, in the client SSL profile used, whether I need to import the client private(or public) key into the BIG-IP since it will have to present the key for authentication when request is made.
I am using the “require” option so the connection would fail unless the authentication succeeds.
Thanks for your assistance.
