DNS ZONE for GTM
I’ve been asked to create a subdomain for a GTM, I’m using Windows DNS and the gtm is using domain name of an existing zone.
Gtm.test.com
How can I set this up if zone test.com already exist?
could you add more explanation what you are going to reach? Where test.com is hosted on? Is Gtm.test.com is a sub domain or a DNS record?
What zone do you need to create on GTM?
You might want to review
K34150459: Delegating a subdomain to a remote DNS name server from the BIG-IP DNS system
which explains glue records pointing the subdomin to the new name server.
Based on your description, I think you need to reverse the implementation - pointing the new subdomain from your Windows DNS to the gtm, but the process is the same.
S Blakely,
Thank you I will try this tomorrow and update on result.
Hello Surgeon, Could you add more explanation what you are going to reach? Trying to reach GTM.test.com which is F5. Where test.com is hosted on? Hosted on Windows DNS servers. Is Gtm.test.com is a sub domain or a DNS record? This is name give to GTM.
What zone do you need to create on GTM? I was told to create a zone and include gtm01.test.com and gtm02.test.com which are listeners for GTM. Thank you.
Try this K277: Delegating a subdomain to a BIG-IP DNS or BIG-IP Link Controller system from another DNS server
surgeon, Thank you for the document I was able to setup delegation and assign name servers for GTM. S Blakely thank you as well for taking the time in replying.
Please accept my answer then Try this K277: Delegating a subdomain to a BIG-IP DNS or BIG-IP Link Controller system from another DNS server
