DNS Resolver for System Configuration not working
Hi ,
Is there a way to check which name server LTM would consider using which it would create the ephemeral node ? I have 4 configured 2 are reachable and 2 are unreachable. Still LTM is not creating the ephemeral node. Any suggestions would be helpful.
Suggestions: If 2 ​ephemeral node is resolving out of 4 mean dns is resolving ip address.
Did ​you run the dig command to check right name server?
Try below command.​ Example:
dig example.com +short +identify
dig foo.example.com +all
​Let’s us know the issue.
Thanks​
Hi Samir,
I meant i have 4 name servers configured. But ephimeral node still doesn’t populate.
Out of 4 two name servers are reachable from device and 2 are not reachable. Ideally it should populate the ephimeral node but issue here is it doesn’t.
