Problem this snippet solves:
This iRule will extract the DNS Query Name in the absence of a DNS profile being applied to a Virtual Server.
How to use this snippet:
# This is a shameless rip from an old Devcentral post DNS Hostname Parsing iRule that, to the best of my knowledge, never made it to a Code Share.
To use this code, simply apply this to a UDP Virtual Server that processes DNS traffic. (No DNS Profile necessary).
Code :
when FLOW_INIT {
#extract QNAME from QUESTION header
#${i} is a sanity check so this logic won't spin on invalid QNAMEs
set i 0
#initialize our position in the QNAME parsing and the text QNAME
set offset 12
set length 1
set endlength 1
set name ""
#/extract QNAME from QUESTION header
while {${length} > 0 && ${i} < 10} {
#length contains the first part length
binary scan [string range [DATAGRAM::udp payload] ${offset} ${offset}]] c foo
#make the length an unsigned integer
set length [expr {${foo} & 0xff}]
if {${length} > 0} {
#grab a part and put it in our text QNAME section
append name [string range [DATAGRAM::udp payload] [expr {${offset} + 1}] [expr {${offset} + ${length}}]]
#Watch the DNS QNAME get built during the loop. Remove the following line for production use.
log local0.info "BUILDING DNS NAME: [IP::client_addr] queried ${name} offset ${offset} length ${length}"
set offset [expr {${offset} + ${length} +1}]
#endlength contains the Last part length
set endlength [expr {${foo} & 0xff}]
if { ${endlength} > 0} {
#put a dot between parts like a normal DNS name
append name "." }
incr i
#Input the required action here, where "${name}" is the variable that is reviewed for decision making.
#Sample action would be a pool statement. The below log statement should be removed for production use.
log local0.info "FINAL DNS NAME: [IP::client_addr] queried ${name}"
Tested this on version:
12.1
