Hello Ashk,
Speaking of GTM without the use of the LTM, you can load balance requests to a pool of DNS servers by creating a listener and assigning a pool to that listener.
Note (load balancing to DNS servers can be achieved by creating a pool from DNS > deliver > load balancing> pool)
the listener on the GTM is different than the virtual server on the LTM, you can check the listener configuration below:
you can notice that there is a DNS profile assigned to the listener. after creating this listener, if you navigate to the LTM > virtual servers, you can find the listener listed as a virtual server (but having a DNS profile assigned), if you tried to remove this profile and then navigated back to DNS > listeners, you will not find the listener anymore.
In conclusion, the GTM listener is used for DNS requests and you can load balance DNS requests across different backend servers inside a GTM pool. The GTM pool can have its own monitor same as LTM.
regarding the part about “by passing LTM”, I think the LTM will be hosting the services. When the user receives a DNS response, the client will initiate a new connection (HTTPs for example) and start communicating with the IP that was returned from the GTM, which I believe it will be hosted on the LTM.
There is a difference between the connection opened with the GTM (just to receive a DNS response) and the connection which is opened with the LTM (service connection) for example: retrieving a home page for any of your services.
There are cases, where both LTM and GTM are hosted on the same BIG-IP, so the client will initiate another connection with the same F5 to open a connection with the service.
One last thing, regarding the delegation:
“test.facebook.com > xyz.facebook.com/abc.facebook.com/efg.facebook.com”
You can check the below article for delegating records using zone runner:
If i didn’t answer your main request, please clarify it further.
Thanks,
Mohamed Salah
