DNS Configuration for LC
Hi everyone,
I am really in need of some correct information, when we are installing the F5-LC, I need to understand the changes we have to make to the DNS Zone file… as there are no document available from F5 it’s getting really difficult for me to sort it out. Any level of help is highliy appreciate.
Regards,
Hello,
With LC , you have to delegate the name resolution for each host in your zone mydomain.com.
Imagine you have 2 ISP and so 2 ranges 10.10.10.0 /24 and 20.20.20.0/24
In the DNS
lc1.mydomain.com A 10.10.10.254 --> IP of your Big-ip in ISP 1 range
lc2.mydomain.com A 20.20.20.254 --> IP of your Big-ip in ISP 2 range
For each WideIp you have in your config (eg www)
; Delegated sub-zone www.mydomain.com
www NS lc1.mydomain.com
www NS lc2.mydomain.com
; End delegation
Hope this help you.
Regards,
Fred.
Hi Fredr,
Thanks for your reply I have done the following. will you pls help me in the below
Correct me where m i wrong…
wip.ab.edu.xx NS lc1.ab.edu.xx
wip.ab.edu.xx NS lc2.ab.edu.xx
lc1.ab.edu.xx A 10.10.10.254
lc2.ab.edu.xx A 20.20.20.254
service.ab.edu.xx CNAME service.wip.ab.edu.xx
and so on for all other services… is this correct floww… ???
Hi ,
One thing i don’t understand in your example, where is service.wip.ab.edu.xx ?
I think with GTM, you can manage a DNS Zone (like wip.ab.edu.xx) but not with LC.
In my mind GTM = SOA , LC = NS.
In my deployment i will have :
In the DNS zone ab.edu.xx
service.ab.edu.xx NS lc1.ab.edu.xx
service.ab.edu.xx NS lc2.ab.edu.xx
In the LC (Inbound Wide IP menu)
service.ab.edu.xx with members .
Regards,
Fred
Hi Fred,
I have created wide IP in the LC wide ip list as “service.wip.ab.edu.xx” and currently in the DNS zone file the entries is like “service.ab.edu.xx” so the DNS enteries i have have planned to changed as i showed in the above post is correct or not???
CURRENT ENTERY IS LIKE THIS TELL ME WHAT SHALL I CHANGE… now when the LC is coming into picture
ab.edu.xx NS ns1.ab.edu.xx
ab.edu.xx NS ns2.ab.edu.xx
ns1.ab.edu.xx A 1.1.1.1 <------ DNS server 1
ns2.ab.edu.xx A 2.2.2.2 <------ DNS server 2
service1.ab.edu.xx A 1.1.1.2
AS PER MY UNDERSTANDING THE cahnges in the above entry should have happened like this
service1.ab.edu.xx CNAME service1.wip.ab.edu.xx
lc1.ab.edu.xx A X.X.X.X
lc2.ab.edu.xx A Y.Y.Y.Y
Where m i going wrong.
Could you try :
service1.wip.ab.edu.xx NS lc1.ab.edu.xx
service1.wip.ab.edu.xx NS lc2.ab.edu.xx
As per my understanding wip.ab.edu.xx is a DNS Zone , you can only delegate host name resolution to the LC not Zone.
Regards,
Fred
I will check it out shortly it sounds logical and should work… some of the enteries in the existing DNS is binded to the same ip and should be entered as an Alias of a particular entry like…
IN THE CURRENT SETUP
www.ab.edu.xx A 32.32.32.32
service3.ab.edu.xx A 32.32.32.32
service4.ab.edu.xx A 32.32.32.32.
and so on…
so what shall i do with such records in GTM there is an option of Alias but not in LC so what should be done in this case… ???
I think 2 options :
one delegation in DNS and one wide ip in LC
www.ab.edu.xx NS lc1.ab.edu.xx
www.ab.edu.xx NS lc2.ab.edu.xx
with N CNAME in the DNS for service3 , service4 …
OR
N delegations in DNS and N wide ip in LC
I never did such configuration in my own deployment.
Regards,
Fred
Hi Fred it got a little bit mixed up i will write here what i have understood from your reply.
www.ab.edu.xx CNAME www.wip.ab.edu.xx
service2.ab.edu.xx CNAME service2.wip.ab.edu.xx
service3.ab.edu.xx CNAME service3.wip.ab.edu.xx
www.wip.ab.edu.xx NS lc1.ab.edu.xx
www.wip.ab.edu.xx NS lc2.ab.edu.xx
service2.wip.ab.edu.xx NS lc1.ab.edu.xx
service2.wip.ab.edu.xx NS lc2.ab.edu.xx
service3.wip.ab.edu.xx NS lc1.ab.edu.xx
service3.wip.ab.edu.xx NS lc2.ab.edu.xx
AND ON THE LC I CREATED ALL THE INDIVIDUAL WIDE-IP ENTRIES
www.wip.ab.edu.xx
and so on…
well this really looks like so many entries in the DNS zone file if i have to change all the entries… is there no way where it looks more organized rather than all individual entries looking more dispersed…
Yes, that s what i want to explain in the option 2.
The option 1 could be
service2.ab.edu.xx CNAME www.ab.edu.xx
service3.ab.edu.xx CNAME www.ab.edu.xx
And on the LC , only one individual WideIp entry
www.wip.ab.edu.xx
and nothing else
Don’t know which solution wouldl be better than the other.
What about the reverse lookup zone do I have to make any changes there or no need the reverse lookup zone entry will remain the same on the current DNS server.???
Hi Fred,
Are you still following the thread… waiting for your reply … Also if you or any one may answer… Does LC do the link aggregation or no??? like if i have 3 ISP each of 10Mbps Bandwidth so will it be treated as a 30Mbps pipe to the internet or no can someone reply for this.
Regards,
LC does NOT do link aggregation. It purely does load balancing across the links, based on availability, and LB method.
Thanks Laudec
