Need F5 guidance on how to configure and validate NXDOMAIN protection specifically for a Tier1 Transparent Cache → Tier2 Recursive Resolver architecture.
Where the NXDOMAIN Query attack vector is evaluated.
Whether AFM can stop the offending query at Tier1 before it reaches Tier2.
How Detection Threshold EPS should be calculated.
How Detection Threshold % should be calculated.
How Mitigation Threshold EPS should be calculated.
Which counters/logs prove that Bad Actor mitigation is working.
Which BIG-IP DNS profile statistics should be collected.
Which AFM DoS statistics should be collected.
How to correlate AFM attack statistics with PCAP.
Whether negative caching can prevent repeated NXDOMAIN queries from reaching Tier2.
What F5-supported mechanism can prevent random/unique NXDOMAIN queries from being forwarded to Tier2.
