distinguish between Citrix client and any browser
Hello folks
Supposing that I am not an iRules guru, I will ask for help here.
Basically the goal of my mission would be blocking the access to the Citrix portal from the browser (using https://myentrypoint.org) but allow the Citrix client (using the same URL).
I suppose that I should use the user agent or else, but sniffing the packets in both attempts I couldn’t figure it out a discriminating element or else.
Did someone has an idea or already handled this situation?
Regards
Vicentiu
Hi Ethereal,
You should be able to trigger an event based on the User-Agent contained within the HTTP::header, but I would suggest creating an iRule that would just monitor the incoming User-Agents at first (so that you can catch all of the User-Agents that you do not want to block and use the results to make an exclusion list).
Example: CitrixReciever
You could start with something like this:
switch -glob [HTTP::header User-Agent] {
"*MSIE 7.0*" -
"*MSIE 6.0*" -
"*MSIE 5.*" -
"*MSIE 4.*" -
"*Safari*" -
"*Firefox*" -
"*MSRPC*" {
log local0. "Known Browsers to eventuall block."
"*CitrixReciever*" {
log local0. "Known Citrix Client"
default {
log local0. "Unkown User-Agent: [HTTP::header User-Agent]"
After you have logged enough you can change the logging behavior to redirect, blocking, reject, drop or whatever action you like.
I would also suggest these as additional reading. They discuss using the User-Agent as well:
Split out clients using the Citrix Receiver w/ iRule
Redirect based on user browser (mobile)
Hope this helps.
Hi Michael
You’re right. I have sniffed on the client side where due to HTTPS encryption I wasn’t able to see anything.
I will try to “tcpdump” on the F5 and figure it out as a first step what is the exact string for the Citrix Client, then logging for a while is a good idea.
Thank you very much for tips.
Vicentiu
