I have multi-segment BigIP LTM deployed. Does any one have an idea how to display ARP cache for non-default routing domain ?
Both “arp -an” from bash and “show /net arp” from TMSH display only entries associated with VLANs in default routing domain.
thanks,
Marek
hoolio
January 27, 2011, 7:28am
2
Hi Marek,
I’m not sure on this one. If you don’t get a reply here, you could open a case with F5 Support. If you get an answer could you reply back here for future reference?
Thanks, Aaron
hoolio
January 27, 2011, 7:37am
3
Great. Thanks for the info.
Aaron
Now that bigpipe is getting old and version 11 focus on tmsh, is there a similar command that I can run in tmsh?
I tried this:
show | grep
but that shows nothing. I have to admit that I ran this on a version 10.2.2, is there a command in v11 that works?
//Ed
tmsh show net arp should get you started, don’t have a setup with multiple routing domains around to check for extra options.
nitass
April 5, 2012, 9:39am
6
e.g.
sroot@bigip1(Active)(/Common)(tmos) show net arp
Net::Arp
Name Address HWaddress Vlan Expire-in-s ec Status
10.10.10.101%10 10.10.10.101%10 0:50:56:b3:8:d3 /Common/internal 293 resolved
10.10.10.102%10 10.10.10.102%10 0:50:56:b3:8:f7 /Common/internal 296 resolved
