Is there a cli command by which we can display the hostname of the f5 Device using the cli?
In F5 unix shell you can print hostname name by typing command
hostname
Python SDK
>>> settings = bigip.sys.global_settings.load()
>>> print settings.hostname
LAB1.mydomain.com
OR
Alternatively you can refer this
set hostname [tmsh::get_config /sys global-settings hostname]
puts [tmsh::get_field_value [lindex $hostname 0] hostname]
tmsh
tmsh list sys global-settings hostname
iControl REST
curl -sku admin: https:///mgmt/tm/sys/global-settings?\$select=hostname
I wasn’t able to get the code from f5_rock to work (it’s most likely my fault) but I did get the hostname with the code below. It’s a little verbose because I had to run the tmsh command to show the settings and then I used .lstrip and .strip to clean the data up. Happy coding!
from f5.bigip import ManagementRoot
mgmt = ManagementRoot("your_f5_ip_address", 'username', 'password')
x = mgmt.tm.util.bash.exec_cmd('run', utilCmdArgs='-c "tmsh list sys global-settings hostname | grep "hostname""')
hostname = str(x.commandResult)
hostname = hostname.strip().lstrip('hostname').strip()
print(hostname)
- from TMSH:
- from Linux shell (run util bash):
echo $HOSTNAME
