Just received the above message. Can someone tell me what this means and what needs to be done please?
You may have to remove unwanted files from the system.
See SOL14403
Hi smurteira,
This is a warning message by diskmonitor utility, which is a script that runs periodically on the BIG-IP system and alerts you if the partition space or volumes reach a defined threshold.
Here are some recommendations to avoid this situation.
You can also check the size of the main folders by typing: df -h on bash.
**6.9G 286M 6.3G 5% /var/log**
none 6.9G 924K 6.9G 1% /dev/shm
none 6.9G 45M 6.9G 1% /shared/rrd.1.2
none 6.9G 25M 6.9G 1% /var/tmstat
none 6.9G 1.6M 6.9G 1% /var/run
prompt 4.0M 28K 4.0M 1% /var/prompt
none 6.9G 0 6.9G 0% /var/loipc
Thank you. I will look into cleaning up space with these recommendations.
