Discover Device (Python code sample)
Problem this snippet solves:
This Python client code sample uses Enterprise Manager’s device inventory to discover a list of devices managed by the referenced Enterprise Manager.
Code :
#!/usr/bin/python
import sys
import pycontrol.pycontrol as pc
MIN_ARGS = 4
NUM_DEVICE_ARGS = 3
USAGE = "Management_EM_discovery_devices <em_address> <em_username> <em_password> [<device address=""> <device username=""> <device address="">] ..."
if (len(sys.argv) < (MIN_ARGS + NUM_DEVICE_ARGS)) or (((len(sys.argv) - MIN_ARGS) % NUM_DEVICE_ARGS) != 0):
    print "Usage: %s" % USAGE
    sys.exit()
em_address = sys.argv[1]
em_username = sys.argv[2]
em_password = sys.argv[3]
num_devices = (len(sys.argv) - MIN_ARGS) / NUM_DEVICE_ARGS
device_addresses = []
device_usernames = []
device_passwords = []
for i in range(num_devices):
    index = MIN_ARGS + (i * NUM_DEVICE_ARGS)
    device_addresses.append(sys.argv[index])
    device_usernames.append(sys.argv[index + 1])
    device_passwords.append(sys.argv[index + 2])
ic = pc.BIGIP(
    hostname = em_address,
    username = em_username,
    password = em_password,
    fromurl = True,
    wsdls = ['Management.EM'])
task_id = ic.Management.EM.discover_devices(addresses = device_addresses,
                                            usernames = device_usernames,
                                            passwords = device_passwords)
print "Discovery task started with task ID: %s"% task_id</device></device></device></em_password></em_username></em_address>
