Disallow Robots
Will the following iRule work for disallowing robots?
Thanks,
if {[HTTP::path] eq “/robots.txt”}
HTTP::respond 200 content "
User-agent: *
Disallow: /
That is close. robots.txt is a text file, so you don’t need to send HTML tags in the response. You can use \r\n to insert a new line:
   if {[string tolower [HTTP::path]] eq "/robots.txt"}{
      HTTP::respond 200 content "User-agent: *\r\nDisallow: /"
It looks like Google has a robots.txt analyzer you might be able to use to verify your rule:
How do I check that my robots.txt file is working as expected? (Click here)
Aaron
Can you confirm the /robots.txt file is in the root of the website?
thanks
If you want to check for any path ending in /robots.txt, you could use:
   if {[string tolower [HTTP::path]] ends_with "/robots.txt"}{
But the common use is for a robot to only request /robots.txt.
Aaron
