Hello.
We are trying to disable USB ports in all devices of the datacenter for security reasons.
Checking USB devices already conected we can see these:
lsusb
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 002 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 001 Device 002: ID 8087:0024 Intel Corp. Integrated Rate Matching Hub
Bus 002 Device 002: ID 8087:0024 Intel Corp. Integrated Rate Matching Hub
Bus 001 Device 003: ID f5f5:1002
Checking dependencies we got this:
lsusb -t
Bus 2
`-Dev 1 Vendor 0x1d6b Product 0x0002
`-Dev 2 Vendor 0x8087 Product 0x0024
Bus 1
`-Dev 3 Vendor 0xf5f5 Product 0x1002
It seems that "
" and "
" are sockets to connect other USB devices and "
f5f5:1002
" seems that is something connected to thoses sockets.
We think that it’s possible to disable all USB devices just disabling the driver of the parent socket (
To do so, we are planning to include the driver used by “Linux USB socket” at modprobe blacklist.
usb-devices
T: Bus=01 Lev=00 Prnt=00 Port=00 Cnt=00 Dev= 1 Spd=480 MxCh= 2
D: Ver= 2.00 Cls=09(hub ) Sub=00 Prot=00 MxPS=64 Cfgs= 1
P: Vendor=1d6b ProdID=0002 Rev=02.06
S: Manufacturer=Linux 2.6.32-431.56.1.el6.f5.x86_64 ehci_hcd
S: Product=EHCI Host Controller
S: SerialNumber=0000:00:1a.0
C: Ifs= 1 Cfg= 1 Atr=e0 MxPwr=0mA
I: If= 0 Alt= 0 EPs= 1 Cls=09(hub ) Sub=00 Prot=00 Driver=hub
So, we should include
blacklist ehci_hci
line at
/etc/modprobe.d/blacklist.conf
and reboot the system.
The question starts here. What is exactly the device connected to
f5f5:1002
Checking F5 Doc it seems that could be the Unit-key --> myF5
Do you know if this is true?
What is the best way to disable the USB ports at F5 BIG-IP?
KR, Dario.
