All,
Our security team has found vulnerability on F5 self IP. when I am doing https:// I am getting the GUI for F5 LTM.. please suggest how can I disable and will there be any impact.
Thanks.
All,
Thanks.
If you want just to change the Configuration Utility ssl cipher list, so allow https access to the GUI through the SelfIP, but restrict ciphers, then there are threads in Devcentral and Ask F5. See
SOL13405: Restricting Configuration utility access to clients using high encryption SSL ciphers (11.x) 404 Page not found | BIG-IP Documentation
