Hello,
I have a question about disabling snat on a virtual server. Currently in this environment when there is a need to disable snat, we point the gateway on the server to use the F5 floating self IP. On the router for this subnet, we add a host route back to the F5 floating self IP for the server. For the non load balanced traffic we use a virtual forwarding server like this.
profile fastL4 FastL4_no_Idle_Timeout_Indefintie {
defaults from fastL4
idle timeout indefinite
tcp close timeout indefinite
virtual forward {
ip forward
destination any:any
mask 0.0.0.0 profiles
FastL4_no_Idle_Timeout_Indefintie {}
My question is, if the forwarding VIP profile is changed to allow asymmetric connections as shown below, will this remove the need to route all client traffic back to the F5 floating self IP? Would there no longer be a need to add a static route for this server in the router?
profile fastl4 test {
loose-initialization enabled
loose-close enabled
reset-on-timeout disabled
