disabling protocol
Hi, What is the difference between the below procedures 1) tmsh modify sys http ssl-protocol ‘all -SSLv2 -SSLv3 -TLSv1’
tmsh list sys http ssl-protocol sys httpd { ssl-protocol “all -SSLv2 -SSLv3 -TLSv1” }
2) tmsh list /ltm profile client-ssl Test options ltm profile client-ssl Test { options { dont-insert-empty-fragments no-tlsv1 } }
If we want to disable tlsv1 and keep only tlsv1.1 and 1.2 , it can be do with CIPHERS ? ( ciphers DEFAULT) ,If yes what would be the string ?
Hello,
This command “tmsh modify sys http” modifies F5 gui console, if you want to modify F5 Virtual server SSL configuration you should use “ltm profile”
