We have a few cases for an internal application where a great number of clients will be hitting GTM via delegation, which means that all users requesting from each delegation will be persisted accordingly. We want the persistence on each wideIP , but not for everyone. Is there an alternative to the persist command that will achieve this desired behavior? In the rule below, I am attempting to not persist if the requests are from a couple subnets, however, I get an error.
01070151:3: Rule [nopersist] error:
line 4: [undefined procedure: persist] [persist none ]
when DNS_REQUEST {
if {[IP::addr [IP::client_addr] equals 10.1.1.0/24] or \
[IP::addr [IP::client_addr] equals 10.2.1.0/24]}{
persist none
ttl Overrides the default time-to-live value. Overrides the default time-to-live value. If this command is used for a CNAME, the value overrides the default of 0. If this command is used for a pool, the value overrides the time-to-live value for that pool.
when DNS_REQUEST {
if { [IP::addr [IP::client_addr]/24 equals "10.1.1.0"] \
or [IP::addr [IP::client_addr]/24 equals "10.2.1.0"] } {
ttl 0
At the wideIP level, I presume this means persistence, and at the pool level, I presume this means the actual TTL. How do I ensure this is applied at the wideIP level?
…unsolicitated commentary to follow…
Could something other than TTL have been selected as a nomenclature for persistence on the GTM?
We are dealing with some crawlers which we didnt want to redirect with a CNAME. Persist none would be ideal. Was curios if you got a resolution on that case. ( we are version 9.4.6 ).
Also is it possible to do a class lookup rather than a nested if.
