Disable TLSv1.1 on management interface
This question is for an F5 LTM 10200 running version 15.x. How do you disable TLSv1.1 on management interface without disabling TLS 1.1 on the entire device.
Thanks in advance
You can change the ciphers and tls versions via tmsh.
Cheers,
KEes
