Angelo
February 7, 2013, 10:47am
1
Hi
I have a streaming enabled on one of VS running SSL. now i need to configure that VS to work on port 80 and 443 how do i disable the streaming when a client connects on port 80 and enable it when the client connects on 443
this is the I-rule
STREAM::disable
HTTP::header remove “Accept-Encoding”
when HTTP_RESPONSE {
if {[HTTP::header value Content-Type] contains “text”}{
STREAM::expression {@http://esf.mtn.co.za @https://esf.mtn.co.za @}
STREAM::enable
Try this;
STREAM::disable
HTTP::header remove "Accept-Encoding"
if { [TCP::local_port] == 443 } {
if { [HTTP::header value Content-Type] contains "text" } {
STREAM::expression {@http://esf.mtn.co.za@https://esf.mtn.co.za@}
STREAM::enable
Angelo
February 8, 2013, 7:08am
3
Thanks Steve as per usual your a legend…
nitass
February 10, 2013, 11:34am
5
i think TCP::local_port in HTTP_REESPONSE event would return server-side’s bigip port.
e.g.
[root@ve10:Active] config b virtual bar list
virtual bar {
snat automap
pool foo
destination 172.28.19.252:1234
ip protocol 6
rules myrule
profiles {
http {}
tcp {}
[root@ve10:Active] config b pool foo list
pool foo {
members 200.200.200.101:5678 {}
[root@ve10:Active] config b rule myrule list
rule myrule {
log local0. "--"
log local0. "\[IP::remote_addr\] [IP::remote_addr]"
log local0. "\[TCP::remote_port\] [TCP::remote_port]"
log local0. "\[IP::local_addr\] [IP::local_addr]"
log local0. "\[TCP::local_port\] [TCP::local_port]"
log local0. "--"
log local0. "--"
log local0. "--"
[root@ve10:Active] config tail -f /var/log/ltm
Feb 10 20:21:52 local/tmm info tmm[4884]: Rule myrule : --
Feb 10 20:21:52 local/tmm info tmm[4884]: Rule myrule : [IP::remote_addr] 192.168.206.31
Feb 10 20:21:52 local/tmm info tmm[4884]: Rule myrule : [TCP::remote_port] 49687
Feb 10 20:21:52 local/tmm info tmm[4884]: Rule myrule : [IP::local_addr] 172.28.19.252
Feb 10 20:21:52 local/tmm info tmm[4884]: Rule myrule : [TCP::local_port] 1234
Feb 10 20:21:52 local/tmm info tmm[4884]: Rule myrule : [IP::remote_addr] 200.200.200.101
Feb 10 20:21:52 local/tmm info tmm[4884]: Rule myrule : [TCP::remote_port] 5678
Feb 10 20:21:52 local/tmm info tmm[4884]: Rule myrule : [IP::local_addr] 200.200.200.10
Feb 10 20:21:52 local/tmm info tmm[4884]: Rule myrule : [TCP::local_port] 49687
