can you please suggest me to how to Disable Default System Accounts in Virtual edition LB version 14.0.0.4
Girishf5,
check out support article K52286304 to identify the default system accounts, and then check K15632 and/or K14943 for detailed instructions how to disable/remove them.
BIG-IP system administrative accounts
Disabling the admin and root accounts using the Configuration utility or tmsh
Removing the default BIG-IP administrative user
Cheers, Kai
