hi all,
one of my customer was doing a vulnerability scan and prompt with a message
“Negociated with the following insecure cipher suites: TLS 1.2 ciphers tls_rsa_with_3des_ede_cbc_sha”
i have search through google, devcentral and askf5. however, even tho there are alot of discussion going on, there is no indication how to block or disable the cipher.
it will be good if someone can point me the right direction or material that can help me with the above mentioned,
thank you.
hi vitaliy,
thanks for the link that you have attached. i have gone through the items but it seems that i couldnt disable the cipher suite.
but i have opened a support case with support. will feedback here once i got a reply from support.
This cipher string will disable 3DES as well as prioritize PFS and GCM.
!EXPORT:!DH:!MD5:!SSLv3:!DTLSv1:ECDHE+AES-GCM:ECDHE+AES:RSA+AES-GCM:RSA+AES
tmm --clientciphers '!EXPORT:!DH:!MD5:!SSLv3:!DTLSv1:ECDHE+AES-GCM:ECDHE+AES:RSA+AES-GCM:RSA+AES'
ID SUITE BITS PROT METHOD CIPHER MAC KEYX
0: 49200 ECDHE-RSA-AES256-GCM-SHA384 256 TLS1.2 Native AES-GCM SHA384 ECDHE_RSA
1: 49199 ECDHE-RSA-AES128-GCM-SHA256 128 TLS1.2 Native AES-GCM SHA256 ECDHE_RSA
2: 49192 ECDHE-RSA-AES256-SHA384 256 TLS1.2 Native AES SHA384 ECDHE_RSA
3: 49172 ECDHE-RSA-AES256-CBC-SHA 256 TLS1 Native AES SHA ECDHE_RSA
4: 49172 ECDHE-RSA-AES256-CBC-SHA 256 TLS1.1 Native AES SHA ECDHE_RSA
5: 49172 ECDHE-RSA-AES256-CBC-SHA 256 TLS1.2 Native AES SHA ECDHE_RSA
6: 49191 ECDHE-RSA-AES128-SHA256 128 TLS1.2 Native AES SHA256 ECDHE_RSA
7: 49171 ECDHE-RSA-AES128-CBC-SHA 128 TLS1 Native AES SHA ECDHE_RSA
8: 49171 ECDHE-RSA-AES128-CBC-SHA 128 TLS1.1 Native AES SHA ECDHE_RSA
9: 49171 ECDHE-RSA-AES128-CBC-SHA 128 TLS1.2 Native AES SHA ECDHE_RSA
10: 157 AES256-GCM-SHA384 256 TLS1.2 Native AES-GCM SHA384 RSA
11: 156 AES128-GCM-SHA256 128 TLS1.2 Native AES-GCM SHA256 RSA
12: 61 AES256-SHA256 256 TLS1.2 Native AES SHA256 RSA
13: 53 AES256-SHA 256 TLS1 Native AES SHA RSA
14: 53 AES256-SHA 256 TLS1.1 Native AES SHA RSA
15: 53 AES256-SHA 256 TLS1.2 Native AES SHA RSA
16: 60 AES128-SHA256 128 TLS1.2 Native AES SHA256 RSA
17: 47 AES128-SHA 128 TLS1 Native AES SHA RSA
18: 47 AES128-SHA 128 TLS1.1 Native AES SHA RSA
19: 47 AES128-SHA 128 TLS1.2 Native AES SHA RSA
you can also just add “!3DES” to whatever cipher string currently in use.
