I have followed a couple of posts around trying to figure out how to make this change but so far without any luck. I have a medium priority call in with F5, but I figured while I am waiting for my call back “within 8 hours” I might post this question here.
Recently we have been undergoing PCI Compliancy scans. One of the recurring issues that we have is:
SSL Server Allows Anonymous Authentication Vulnerability
The Secure Socket Layer (SSL) protocol allows for secure communication between a client and a server. The client usually authenticates the server using an
algorithm like RSA or DSS. Some SSL ciphers allow SSL communication without authentication. Most common Web browsers like Microsoft Internet Explorer,
Netscape and Mozilla do not use anonymous authentication ciphers by default.
A vulnerability exists in SSL communcations when clients are allowed to connect
using no authentication algorithm. SSL client-server communication may use several different types of
authentication: RSA, Diffie-Hellman, DSS or none. When ‘none’ is used, the
communications are vulnerable to a man-in-the-middle attack."
Our BigIP device hosts our SSL certificates for the load balanced sites behind it. If the certificates were directly on our Apache servers, then turning off the anonymous authentication would be trivial. However I have yet to find a solution with the BigIP. A setting? An iRule? Any help or advice would be greatly appreciated!
The ‘b httpd’ commands only modify the admin GUI configuration. If you want to specify which ciphers can be used for a LB VIP, you can modify the client SSL profile or use an iRule. Check this post for details on both methods:
Surprisingly there is no help available for this vulnerability for 11.6.0 Firmware version. However I was expecting that after disabling SSLv2/TLS1 this cipher suite will be disabled, however that wasn’t fact.
I had to manually disable this particular cipher from the Client-SSL Profile.
After updating the Client-SSL Profile, I verified the HTTPS service on Qualys and DigiCert’s SSL Test site and it was fixed. I hope this would help someone.
within my Client SSL configurations I have this for Ciphers: NATIVE:!MD5:!EXPORT:!DES:!SSLv3:!RC4:@SPEED Do I add HIGH:!ADH within there or replace the entire string with it? Thanks!
I think you can use your current cipher suites defined in your Client-SSL Profile, by adding !ADH within the same suite, to discard the ADH from being negotiate.
You may update your current cipher suite to the following.
The Secure Socket Layer (SSL) protocol allows for secure communication between a client and a server. The client usually authenticates the server using an algorithm like RSA or DSS. Some SSL ciphers allow SSL communication without authentication. Most common Web browsers like Microsoft Internet Explorer, Netscape and Mozilla do not use anonymous authentication ciphers by default. A vulnerability exists in SSL communications when clients are allowed to connect using no authentication algorithm. SSL client-server communication may use several different types of authentication: RSA, Diffie-Hellman, DSS or none. When ‘none’ is used, the communications are vulnerable to a man-in-the-middle attack.
I have changed the ciphers as follows … solved the problem …
OLD cipher : NATIVE:!SSLv3:!MD5:!EXPORT:!DES:!DHE:!EDH:!RC4:@SPEED
NEW cipher : NATIVE:!SSLv3:!MD5:!EXPORT:!DES:!DHE:!EDH:!RC4:!AES-GCM:@SPEED
Following website also let you know if its been disabled or not :
