Direct Access 2012 and f5
We are testing Direct Access 2012 and are planning to use the f5 to handle load balancing between two DA servers.
I haven’t found much info specific to using f5, mainly this:http://www.f5.com/pdf/white-papers/…ess-tb.pdf
The only real technical documentation is the old Forefront UAG back in 2009:
https://devcentral.f5.com/tech-tips…bjKNinnbaM
http://www.f5.com/pdf/deployment-guides/f5-uag-dg.pdf
I would like verifaction that the this older documention is still relevant with DA 2012.
Mykel
Mykel,
The inbound Direct Access load balancing configuration (Teredo, IP-HTTPS) is consistent between UAG and the versions of DA.
I am reworking our guidance around the “Manage-Out” scenario. I’ve got guidance ready for IP-HTTPS based Manage Out connections, and the guidance for Teredo based Manage Out is still being developed. Please feel free to reach out to me (r.korock@f5.com) if you need more details.
Hi Ryan, I also need Teredo based Manage out solution document , as i am about to implement this in our environment.
do you have any document to implementing Direct access 2012 with F5 load balancing. the document i have found is for UAG only but we are implementing direct access 2012 with external load balancer(F5).
Hi Ryan, Not seen any of the promised Manage Out guidance, neither IPHTTPS nor Teredo. Did you succeed in getting MO working at all? Many thanks.
Just posted the guidance here It should eventually make it into a deployment guide, but until then, that blog post should have the information you need. Sorry for the wait, and let me know if anything in there needs clarification!
Impressive work Ryan. Shame about Teredo since Microsoft say it’s faster than IPHTTPS. Still, when combined with GTM, this is the only documented solution to allow Manage Out in a Multisite deployment of DirectAccess. I think you’ve accidentally duplicated the lower screenshots though.
I’m looking for a document on how to use F5 with two DA servers. F5 will provide the load balancing and the two DA servers (cluster) will be the fault tolerant. In the DA wizard for the DIP (dedicated IP address) do we use the VIP? Any article on this? Thanks.
