Dear Techies,
Please clear me the difference between HTTPS & HTTPS_443 monitor.
Dear Techies,
https_443 can assign to wildcard (any) port pool member because port number is hardcoded in the monitor. ![]()
root@(B6900-R69-S5)(cfg-sync Standalone)(Active)(/Common)(tmos) list ltm monitor https https_443
ltm monitor https https_443 {
cipherlist DEFAULT:+SHA:+3DES:+kEDH
compatibility enabled
defaults-from https
destination *:https
interval 5
ip-dscp 0
send "GET /\r\n"
time-until-up 0
timeout 16
defaults-from https
destination *:https
interval 5
ip-dscp 0
send "GET /\r\n"
time-until-up 0
timeout 16
The difference between HTTPS and HTTPS_443 monitors is in Alias Service Port. Alias Service Port * All Ports - for HTTPS monitor. Alias Service Port HTTPS - for HTTPS_443 monitor.
Nitass it will be really helpful for me if you clear it by giving a example. thanks…
e.g.
root@(B6900-R69-S5)(cfg-sync Standalone)(Active)(/Common)(tmos) create ltm pool foo members add { 1.1.1.1:any }
root@(B6900-R69-S5)(cfg-sync Standalone)(Active)(/Common)(tmos) modify ltm pool foo monitor https
01070622:3: The monitor /Common/https has a wildcard destination service and cannot be associated with a node that has a zero service.
root@(B6900-R69-S5)(cfg-sync Standalone)(Active)(/Common)(tmos) modify ltm pool foo monitor https_443
root@(B6900-R69-S5)(cfg-sync Standalone)(Active)(/Common)(tmos) list ltm pool foo
ltm pool foo {
members {
1.1.1.1:any {
address 1.1.1.1
session monitor-enabled
state checking
monitor https_443
