I’m trying to configure my F5 LTM 11.3 to be able to allow server-initiated SSL renegotiations but reject client-initiated SSL renegotiations. In the clientssl profile I’ve configured a renegotiation period of 600 seconds as I want to be able to renegotiate with the client, but only if I ask for it (Hello Request message sent from the F5 to the client) and after that I’ve unchecked the Renegotiate checkbox as I don’t want to accept the client-initiated renegotiations.
The problem is that it seems that the SSL renegotiation options in the sslclient profile doesn’t allow me to differentiate between client and server initiated renegotiations. If I uncheck the Renegotiation option then I can’t renegotiate with the client when I ask for it because the Hello sent from the client in answer to my Hello Request message is rejected, and I’d like to be accepted as I’ve asked for it.
It’d be nice to have two options, client-initiated renegotiation and server-initiated renegotiation so I could check or uncheck the specific behaviour that I want to allow or reject.
Knowing of this limitation, I’m now exploring if I could solve it with an iRule, but I guess I can’t as the CLIENTSSL_HANDSHAKE event is called when the handshake is finished and I’d need to be able to abort the handshake before it’s made.
So… any way to detect the “Hello Request” message in my iRule to manage the CLIENTSSL_HANDSHAKE accordingly. Anyone has solved this problem of differentiate between client/server initiated renegotiations?
Im not in front of the BigIP GUI right now, but Im pretty sure you can set the renegotiation different for the clientssl profile an the serverssl profile, and then on the VIP don’t use the same SSL profile for Client and Server, ie use different (custom ones) for the respective client and server side.
My explanation maybe is a bit confusing because of the use of the word “server” when I really mean the BigIP.
Think in the SSL connection established between the client and the BigIP. In this SSL connection the renegotiation can be initiated from the client (that’s what I want to reject) or the BigIP (that’s what I want to allow and forc every 600 seconds).
If I uncheck the Renegotiation checkbox in my sslclient profile, then I don’t allow any kind of renegotiaton, neither client initiated nor BigIP initiated.
In a SSL dialog between client and BigIP, there’s a way to differentiate when the BigIP has initiated the negetotiation, and that’s the “Hello Request” message sent from the BigIP when it’s requesting the “Hello” from the client to start the new handshake, and that’s what I thought I could manage from an iRule, but I guess I can’t.
Maybe it’s more clear now my problem… can I allow BigIP initiated renegotiations while rejecting client initiated renegotiations?
Just using my clientssl profile that manages the SSL connection between client and BigIP as the connection between BigIP and internal pool node is HTTP, I don’t use SSL here, just with the Internet clients that connect to my VIP.
Mitigating the THC SSL DoS Threat
http://devcentral.f5.com/weblogs/macvittie/archive/2011/10/28/f5-friday-mitigating-the-thc-ssl-dos-threat.aspx
and
SSL Renegotiation DOS attack – an iRule Countermeasure :
https://devcentral.f5.com/articles/ssl-renegotiation-dos-attack-ndash-an-irule-countermeasure
and here
SSL Renegotiation, Execution Halting and HTTP Rewriting :
https://devcentral.f5.com/articles/20-lines-or-less-49-ssl-renegotiation-execution-halting-and-http-rewriting
Hello, I want to achieve the same thing as described ny Angel Lopez. The point is that I need to block client-to-BIGIP initiated renegotiations while allowing BIGIP-to-client initiated ones (these renegotiations are triggered by an iRule). Although the SSL reneg rate limiting iRule is a good solution it is not good enough for my usecase. Let me explain. Customer is using SSLlabs (SSL Server Test (Powered by Qualys SSL Labs)) to get a summary of the SSL security posture of their site. The use this result to help differentiate their service from competition. This test merely checks if the site allows ssl reneg. As the result is positive it marks this as a negative result. The way around would be to block these client initiated renegs but therefore I need to be able to differentiate.
It may be worth asking why SSL renegotiation is such a bad thing. The initial handshake of an SSL/TLS dialog is used to generate a session encryption key. The longer that key is used the easier it becomes to attack it, so semi-frequent renegotiations are actually a good idea. Now, there is an issue with regular SSL renegotiation, detailed in CVE-2009-3555, that would allow an attacker to insert data into an existing session. This vulnerability has been addressed with RFC 5746, and “secure renegotiation” is a native function of the F5 BIG-IP. I would certainly question whether or not the finding is specific to all SSL renegotiation, or just (insecure) pre-5746 SSL renegotiation.
Except I used the code in the CLIENTSSL_HANDSHAKE event in the CLIENTSSL_CLIENTHELLO event instead. Also instead of using the maxquery variable of 5 I set it to 1 and added an additional flag in the if condition that references that variable that I set when I request renegotiation on the server side. That ensures renegotiation only occurs when initiated by the server.
I tested it using SSLyze --reneg and confirmed it blocked client side renegotiation.
Hello Brett, as I am not good in wrinting iRules by myself, I am usually searching for similar rules and use them. In this case we want to achieve exactly the same. Block all client initiated renegotiations and allow only server intiated renegotiations.
I have applied that iRule, but unfortunately even the very first attemp for connection is being blocked. The session goes SYN → SYN-ACK → ACK → CLIENT_HELLO → RESET (the reset is sent by the BIG-IP). What would cause that, have you experienced any issues with the iRule?
It’s been a while since I’ve looked at this but from reviewing my current setup it looks like I am no longer dropping the connection on CLIENTSSL_CLIENTHELLO. It looks like I’ve disabled the renegotiation setting within the ssl profile and before I initiate the renegotiation within the iRule I call “SSL::renegotiate enable”.
I see, thanks. With the customer we agreed to use the “official” iRule provided by F5 for the DDOS protection, so I think we are good to do that way. Thanks a lot for your reply, even you wrote the answer more than year ago.
