Hello All,
Probably a quick answer, is it possible to have an F5 VS listen on port 443 and have it make the back-end connection to the pool member on 8443?
Is this feature called something?
Thanks all,
Jim
Hello All,
Thanks all,
Jim
Hi Jim,
By default, TMM will perform destination address and port translation when load balancing to a pool. This is enabled by default and configurable using the address and port translation settings on the virtual server properties.
Aaron
Hi Jim,
If you are going to create a standard VS on F5 LTM it does both adress translation as well as port translation when creating a VS you can choose the advanced inplace of basic and down in the configuration it will show you to enable or disable the address and port translation.
Regards,
Thanks all, I see that when you create the VS there is a checkbox at the bottom to allow port and/or address translation! Very cool.
