Difference Between APM & Firepass
Dear All,
Pls help to get difference between APM and Firepass …as Both are known for SSL VPN Solution in F5.
Regards
Hi
Firepass is the legacy device that is no longer supported - myF5
APM is the replacement for Firepass
Firepass is a dedicated VPN solution with dedicated hardware.
this solution was replaced by the APM in spite of F5 continuing to support Firepass (just keep in mind that Firepass is a solution at the end of life):
APM has a lot more functionality:
  • VPN SSL
  • thanks to its brick “Access management and LTM” it can interlock with several authentication methods: SAML, Radius, Web service Auth, cert auth …"
  • Access management: you can secure app by a perimeter security with multiple auth method: SAML Oauth OIDC, Cert, TACACs OAM, …
  • You can also secure and proxyfy non web service (citrix vmware ActivSync).
  • You can easly secure app or vpn access with webservice using Irule
To resume yes both are vpnssl but apm is more:
  • VPNSSL
  • Access Management (security perimeter)
  • You can use LTM/ Irule to communicate with webservice or other task in order to enhance your security or need.
  • You have multiple auth method and now apm support OIDC, SAML …
  • With APM you can secure API now
You have more benefit to use APM.
if you need more details keep me in touch.
regards,
