Team, Recently upgraded one of our VE HA pair from V10.2.4 to V11.5.1 after upgrade devices in device group showing disconnected, we tried the following steps.
Reinitialize the trust in both devices and add it back to device group.
Delete the device group and recreate device group with new trust.
Reboot the device and try the above two methods again.
Touch mcpd db , reboot device and try the above methods.
But still we are facing the same issue, we have a case with f5 1-1728657381 after 48hr there is no response from F5, I never faced such poor support from F5
Are you using a dedicated HA VLAN. Do you have connectivity on this VLAN, can you ping?
Does the Self IP that you are using for HA have the correct port lockdown setting? Set to Allow Default to be sure, you can harden this later if required
Under Devices, has the Configsync and Device Connectivity been configured correctly on both devices? Using IPs from the correct VLAN
Does the device cert on each box look OK - is it in date etc
If any of these need changing then do so and then re-establish the trust between the devices and redo the device group
