Hi guys,
I stuck a little bit with Name in Device object
Example If you set Hostname via GUI it will change Name & Hostname in Device Management->Devices self device object
Also in GUI you can go into Device Management->Devices choose self device object and then you have button “Change Device Name” do you know how you can call it via REST ?
However if change Hostname via REST using “mgmt/tm/sys/global-settings” it will change only Hostname part in Device Management->Devices self object
I also tried to change Name using “mgmt/tm/cm/device” but is seems to ignoring this - my REST query was like bellow - “bigip1 is default name” https://x.x.x.x/mgmt/tm/cm/device/~Common~bigip1 { “name” : “lb01.domain.com” }
Does anyone know how to change Name or advise me what I am doing wrong ?
Regards, Marcin
