Device CSRs
If you generate a device CSR but do not use it to get CA authorised Certificates, and let’s say the device is rebooted. Would you be able to gain the access of device ?
The reason why I ask this is because if it is done on cisco WLC using GUI, you won’t be able to access the GUI, atleast as per cisco site.
you mean via: “System ›› Certificate Management : Device Certificate Management : Device Certificate”
as far as im aware you can reboot without issues. process separate enough to handle this fine.
