Detect IP in a range in iRule
For the IPs in a range for example 91.186.192.0 to 91.186.223.255, how should I structure the datagroup list to detect if the incoming IP is within the that range using the iRule.
There are many IP ranges. If I calculate the CIDR for each range beforehand (an example CIDR for the above range would be 91.186.192.0/19), can I make use of the CIDR to delect if the incoming IP is within the given range using iRule?
This devcentral article may answer your question.
Hi Ashish,
F5s
[IP::addr]
or F5s
[class]
command in combination with an IP-ADDR based data-group can be used can be used to check if a given IP address falls in the range of a given
/CIDR
subnet.
The
[IP::addr]
command is useful if you need to compare just a few different subnets…
if { [IP::addr [IP::client_addr] equals 91.186.192.0/19] } then {
    log local0.debug "The IP matches 91.186.192.0/19"
} elseif { [IP::addr [IP::client_addr] equals 91.186.224.0/19] } then {
    log local0.debug "The IP matches 91.186.224.0/19"
} elseif { [IP::addr [IP::client_addr] equals 91.186.0.0/16] } then {
    log local0.debug "The IP matches 91.186.0.0/16"
    log local0.debug "The IP matches none of the subnets"
Note: The order of thestatement is important for overlapping subnets. The check is always performed as “first-match”.
[if]
Whereas the
[class]
command scales much better if you need to compare multiple subnets…
iRule:
if { [set result [class lookup -value [IP::client_addr] equals DG_MY_SUBNETS]] ne "" } then {
    log local0.debug $result
Data-Group:
ltm data-group internal DG_MY_SUBNETS {
    records {
        91.186.192.0/19 {
            data "The IP matches 91.186.192.0/19"
        91.186.224.0/19 {
            data "The IP matches 91.186.224.0/19"
        91.186.0.0/16 {
            data "The IP matches 91.186.0.0/16"
        0.0.0.0/0 {
            data "The IP matches none of the subnets"
    type ip
Note: The order of the data-group does not matter. The check is always performed as “best-match”
Cheers, Kai
