Detect Geo Location With iRule and Redirect
Hello,
I have this iRule:
    if { [string tolower [HTTP::host]] contains "example.com" && [HTTP::path] eq "/" }{
        set country [whereis [IP::client_addr] country]
        switch $country {
            "US" -
            "UK" -
            "CA" - { HTTP::redirect "https://example.com/${country}" }
The goal being to detect US, UK and CA users and then redirect them to a region specific page on the site. However with the rule enabled we just get back empty reply from F5. Turning it off or requesting Example Domain (multiple trailing slashes) works. I’m thinking it has something to do with how the if statement is structure since adding additional slash characters corrects the problem but this is a bit out of my normal wheelhouse. Usually the F5 tasks I get delegated are updating SSL certificates and simple redirects.
try
    if { [string tolower [HTTP::host]] equals "www.example.com" && [HTTP::path] eq "/" }{
        set client_ip [IP::client_addr]
        set country [string tolower [whereis $client_ip country]]
     switch $country {
            "us" -
            "uk" -
            "ca"  {
Your code is from this link where Leonardo answered.
Does it mean this code never worked since september?
If the redirect is on the same server but to a subdirectory, redirect to a relative URL instead of absolute URL
        switch $country {
            "US" -
            "UK" -
            "CA" - { HTTP::redirect "/${country}" }
