I wanted to see if it was possible to create an iRule that I could apply to an IP forwarding VIP to remove a SNAT.
Example:
Say Network 172.16.0.0/24 wants to talk to 10.32.0.0/24. Right now, there is a default SNAT that will SNAT all traffic from the 172.16.0.0/24 network to a particular IP address.
I have created an IP Forwarding VIP to 10.32.0.0/24, but the IP address will always show up as the previous particular IP address when accessing the 10.32.0.0/24 network.
Is there a way I can apply an iRule to the IP Forwarding VIP that will simply remove the SNAT when destined to these particular networks?
That’s a good start. If traffic hits this VIP and doesn’t match the allowed client IP’s class and/or destination port class, what do you want to do with the traffic? Traffic which hits this VIP wouldn’t default to using the default SNAT, so you’d want to handle those cases explicitly in the iRule. Here is a cleaned up example with more accurate names:
Also note that if you’re on 9.4.4+ you should remove the $:: prefix from the class names in the iRule.
class allowed_clients_class {
network 172.16.0.0/24
class allowed_destination_ports {
22
80
110
when CLIENT_ACCEPTED {
Check if client IP is allowed
if { [matchclass [IP::client_addr] equals $::allowed_clients_class]} {
Check if the requested port is allowed
if { [matchclass [TCP::local_port] equals $::allowed_destination_ports]} {
Disable SNAT for this connection
snat none
Take some action for disallowed destination ports?
drop
Take some action for disallowed client IPs?
drop
It is my belief that you can perform this action using a ‘SNAT’ on a particular VLAN. If these are separate VLANs, I would think you can disable SNAT destined to a particular VLAN. Anyone have experience with this?
A SNAT can provide similar functionality to a VIP and iRule, but the iRule gives you more granularity (source and destination hosts/subnets and ports), the ability to log connections and more specific statistics (b virtual show all versus b snat show all). If the SNAT functionality works for your requirements it is a simpler config option and is probably more efficient than a VIP and iRule.
