We are using F5 for proxy servers gateway, and everything works fine, but due routings in proxy’s if the clients destination is local network, the proxy’s can’t connect to local network, so in web browsers are using cache.pac where is defined, that if destination is local network, traffic goes directly, not via F5. Example:
But clients who can’t read/use the cache.pac can’t connect local network at all, so is it possible on the F5 with irule do same thing as with cache.pac, that if destination is local network F5 redirects all this traffic to the network directly and without any NAT/SNAT?
Do you have a pool of proxy servers and another pool defined to handle the traffic? If so, you can use a rule like this:
Check if host header value only contains numerals or colons ":"
The format is {%[CHARS]}, where CHARS can be a character ranges or single characters.
The literal hyphern character '-' needs to be listed first or last in the character set
if {[scan [HTTP::host] {%[0-9:]}] eq [HTTP::host]}{
Split the host header value on the : if it exists
and check if it's part of the stock private_net datagroup
if {[matchclass [getfield [HTTP::host] ":" 1] eq $::private_net]}{
Use the direct pool
pool direct_pool
Stop processing this event in this rule
return
If we reached here, use the proxy pool
pool proxy_pool
Thank You from the example.
Yes I have proxy pool, but I don’t have so called direct traffic pool yet. And this rule applies only for http traffic or global, as streaming etc may also needed to go directly?
If you don’t have a pool defined to handle the non-proxy requests, you could forward them according to the routing table to their destination. Try replacing ‘pool direct_pool’ with ‘forward’.
Hmm, seems it doesn’t work, as I can’t even enable this irule:
01070394:3: HTTP_REQUEST event in rule (proxy_bypass) requires an associated HTTP or FASTHTTP profile on the virtual server (live-proxy).
As we are sending all traffic without any profile to proxy. Then I trid this without sucess:
when CLIENT_ACCEPTED {
if { [matchclass [IP::local_addr] equals $::255.240.0.0] } {
Can you add an HTTP profile to the VIP and test with the example in my first post above? The HTTP profile is required to allow LTM to parse the request as HTTP.
The private_net class referenced in the example is a stock class of addresses defining RFC1918 internal IP’s:
b class private_net list
class private_net {
network 10.0.0.0/8
network 172.16.0.0/12
network 192.168.0.0/16
If you don’t want to parse the HTTP and can instead look at the requested IP address, you could use something like this:
if { [matchclass [IP::local_addr] equals $::private_net] } {
forward
pool live-proxy-pool
As this rule doesn’t inspect the HTTP headers/data you wouldn’t need an HTTP profile on the VIP.
I can’t as full traffic goes true F5 to proxy’s, without any profiles. So I’ll give try with this second one, but did I understand correctly, that this private_net/local_addr is somewhere already declared or I must declare it/them by myself in this iRule?
If you define a VIP on 0.0.0.0/0.0.0.0.0 on port 80, this more specific VIP would match all port 80 traffic and you could add an HTTP VIP. But if you want to filter based on the destination address of the connection attempt, the second rule would be more efficient and not require an HTTP profile.
The private_net datagroup is predefined in the /config/profile_base.conf, so you don’t need to do anything to reference it.
Tried this global traffic rule, no luck, somehow all traffic will be dropped, direct and also true proxy. Any hint how to solve this is welcome.
If the destination IP address on the client request is what you’re trying to evaluate, can you try this rule on the 0.0.0.0:80 VIP with no HTTP profile?
log local0. "[IP::client_addr]:[TCP::client_port]: Request to [IP::local_addr]:[TCP::local_port] matched local addresses"
forward
log local0. "[IP::client_addr]:[TCP::client_port]: Request to [IP::local_addr]:[TCP::local_port] didn't match local addresses"
Can you try testing a request to an internal IP and an external IP? If it doesn’t work, check the /var/log/ltm log file for log statements from the rule. Make sure you have routing in place for the non-local addresses. A tcpdump might help in troubleshooting any issues.
Strange, I enabled this rule but absolutely nothing (according this rule, all audit etc stuff is still there) appeared in logs? Routing seems to be OK, as default route is our internal gateway.
This is very weird. I even tried to make so called forward pool, but still nothing in logs?
If you add a RULE_INIT event with a log statement, do you see the log statement written to /var/log/ltm? If so, then I’d guess the traffic is matching a more specific VIP or not hitting LTM at all. If you don’t see the log statement, it’s probably because syslog-ng is configured for external logging or customized to not log to the default destination /var/log/ltm.
Added Your suggested iRule to proxy VIP and once into /var/log/ltm appeared:
tail -f /var/log/ltm
Sep 30 12:12:32 tmm tmm[1712]: Rule : Test
And syslog wasn’t configured to the external server at all, so just now I did it. Btw, I’m running since yesterday BIG-IP 9.4.5 Build 1086.1 Hotfix HF2, before it was 9.2.4 Build 031.
Hmm, something new appeared, suddenly I can see logs, and seems no matter what destination ip is (local or external), the log is same:
Sep 30 12:41:38 tmm tmm[1712]: Rule private_net_bypass_proxy_debug : 172.18.15.13:1327: Request to 192.168.121.125:8080 matched local addresses
And if destination ip is local (in private_net group) still no traffic goes true.
Since you use v9.4.5 you must remove the “$” sign when calling a class, so it should be ::private_net instead of $::private_net. (this will make the irule being CMP compatible if using a CMP compatible platform)
if the destination ip is local, do you see at least the log line in /var/log/ltm ?
Ok, I can test it tomorrow, but one more thing, we don’t use transparent, but fixed proxy, like proxy.internal:8080, seems that now this iRule can’t actually forward local traffic as the destination port for all traffic (proxy) is 8080 not 80 or 443 etc. Maybe this iRule need some remap or etc?
If your client connect to the VS on port 443 or 80 and you want to forward the traffic to port 8080 then:
-Your pool member must be configured with port 8080
-Your VS must have port translation checked (switch to advanced configuration in the VS to see this option)
Maybe you can show us your vs and pool configuration that may definitely help. It is in /config/bigip.conf file
VIP is configured without any profile and for all traffic , port translation is enabled, conf is here:
pool live-proxy-pool {
lb method member ratio
action on svcdown reselect
snat disable
nat disable
monitor all gateway_icmp and proxy-www.google.ee and proxy-www.neti.ee
members
192.168.125.114:any
ratio 9
192.168.125.115:any
ratio 7
192.168.125.116:any
ratio 3
virtual live-proxy {
destination 192.168.125.113:any
ip protocol tcp
vlans Virtual enable
persist source_addr
translate service enable
Ok, changed this rule, still all destination ip -s, local and nonlocal are catched as local:
Oct 1 12:50:32 tmm tmm[1712]: Rule private_net_bypass_proxy_debug : 172.18.15.13:4831: Request to 192.168.121.125:8080 matched local addresses
