Hi @davidy2001 ,
well ,
> firstly, From outside user perspective , the destination IP is the " Virtual server = 10.0.30.245" Not The internal Node ip , even users do not know about the node ip.
- The " Virtual server = 10.0.30.245" speaks instead of internal node , all of user knowledge ends up to the
" Virtual server = 10.0.30.245" and they can not know what behind the Big-ip from Real servers " internal nodes “.
- The Process of Destination Nat is a process related to F5 Big-ip which do it without knowledge of users , as it converts " Virtual server = 10.0.30.245” IP to " Internal node ip ".
> Secondly , you Though that the External Floating IP address is the Virtual server address.
well , Floating IP exists only if you deploy a High availability “HA” Clustering between two Appliances of F5 Bigip.
-The External Floating ip acts as the self IP address which you create for the standalone system.
- External Floating ip maintains the reachability of your system and the peer device on network " Switchs , Routers , Firewalls " , This IP is related to Active and Standby units , but it is owned by Active unit until is become done or a hardware failure happens to it , if this failure happen , this IP will move and owned by the standby unit as it will become the Active unit in this Case.
- External Floating IP address is not included in user traffic ip packets.
- External Floating IP in " HA " Clustering is same as self ip in Standalone unit , it used in Layer 2 Arp packets , and the peer device" Layer 3 Switch , Router , Firwall " to F5 uses it as a next hop to forward traffic to F5.
- Without Creating Floating IP address , you will loose reachabilty with F5 outside network peers.
- Floating ip address is called " Virtual IP address " in other Vendors , I think it confuses you because of its name.
- But , Virtual server is the main speaker instead of internal nodes , and it must be included in the IP layes 3 Packets between users and F5.
- Virtual server is the most important component in F5 Big-ip it contains a massive configuration Features adminstrators can do it.
>Note , Virtual IP and Floating ip can have the same IP address , but this is a bad network design and not deployed in almost network architectures.
I hope that helps you.
Ty and Regards
