Deploying a PSC in High Availability mode behind a F5 big-IP Load Balancer
I am trying to setup the Vcenter 6 Platform service controller on HA mode using http://kb.vmware.com/selfservice/search.do?cmd=displayKC&docType=kc&docTypeID=DT_KB_1_1&externalId=2098006 article. I am using 90 days trial version of F5 big-ip 11.3.0 for this setup. However the Virtual IP (VIP) entry created for two PSC nodes is unable to redirect to the PSC while tested to open in the browser :-
I can open the PSC1 /PSC2 in the https://psc1.domainname.com & https://psc2.domainname.com however the VIP entry
https://pscvip.domainname.com does not load and shows the webpage is not available.
Please assist.
health monitor is UP for both? Do you have Automap Enabled on the VIP?
I would verify your virtual servers are setup to use snat auto map and that you have a self ip address for a network that can route to the pool members.
A tcpdump on the BIG-IP would be useful to note where the connection is broken.
something like “tcpdump -ni -0.0:p -s 0 host client ip” where client ip is the address of the client attempting to connect to the virtual server pscvip. The :stuck_out_tongue: (peer flows) will follow the entire flow so when snat is working you can see the translations.
