delete port i rule with specific address
Hi i use an i rule for deleting ports on application servers. But the problem is when i called the ip address:port of an application server i rule deletes the ports of application server. So i want to write an exception for the specific ip address. here is my i rule:
when HTTP_RESPONSE {
if {[HTTP::header exists "Location"]}{
    set org_location [HTTP::header "Location"]
    set http_part [substr $org_location 0 "//"]
    if {$http_part eq "http:"}{
        set remain_part [findstr $org_location $http_part 5]
    elseif {$http_part eq "https:"}{
        set remain_part [findstr $org_location $http_part 6]
    set port_str [findstr $remain_part ":"]
    set port_num [substr $port_str 1 4]
         deletes the ports between 9080 and 9199
    if {($port_num >= 9080) and ($port_num <= 9199)}
            set the_port [substr $port_str 0 5]
            set part1 [substr $org_location 0 $the_port]
            set part2 [findstr $org_location $the_port 5]
            if {$org_location contains $the_port}{
            set org_location "$part1$part2"
            HTTP::header replace Location $org_location}
I want to modify this irule so; if the url contains the ip address, i rule wouldn’t delete the ports.
Thanks for your help
Hi Ibrahim,
you may take a look to the iRule below. It used a less complex syntax using the
[URI::*]
commands to parse the original
Location
header to decide if a rewrite is needed. But also uses a
-glob
based
[string match]
command to identify IPs within the host values.
    if { [set http_location [HTTP::header value "Location"]] ne "" } then {
        if { ( [set uri_port [URI::port $http_location]] >= 9080 ) and
             ( $uri_port <= 9199 ) and not
             ( [string match {[0-9]*.[0-9]*.[0-9]*.[0-9]*} [URI::host $http_location]] ) } then {
            HTTP::header replace Location "[substr $http_location 0 ":$uri_port"][findstr $http_location ":$uri_port" 5]"
Cheers, Kai
