Hi
I know how to delete an adress persistence entry in database with the bigpipe command (bigpipe persist client ip_address delete), but is it possible do delete this persistence entry in database with Irule command ?
Thank you
Fred
Hi
Thank you
Fred
Hi Fred,
You can use ‘persist delete’ to remove a persistence entry from an iRule:
persist
http://devcentral.f5.com/wiki/default.aspx/iRules/persist
Aaron
Hi Aaron
As you answered me… I found it in the wiki at the same time…
Fred
