Delete and Service from iWorkflow when BIG-IP is not reachable
How to delete an ASO from an iWorkflow when the Placement is in status “ERROR_IN_DELETION”? In version 2.3.0 iWorlflow will not let you delete the service until you “Update the service by issuing a PUT or a PATCH to bring the service state out of ERROR_IN_DELETION”. I put the above in quotes because I copied it from the “Remove service” section of: https://devcentral.f5.com/wiki/iWorkflow.APIRef_cm_cloud_tenants_tenant-name_services_iapp.ashx
I found that the directions are not very complete and almost impossible to follow. It seems like they do not work unless you are able to delete the Service very quick after changing the status. This is very hard to manually. I have already solved this problem by writing a script but I am posting this question here so I can make it available to others that may be hitting this problem.
If you are hitting this issue you can get the script from github:
https://github.com/tthomas0702/iwf_aso_delete
This question is resolved by using the script.
Here is the script:
!/usr/bin/python
This is designed to be run locally on iWorkflow to remove stuck ASO in
"ERROR_IN_DELETION" status. See "Remove Service" at:
<a href="https://devcentral.f5.com/wiki/iWorkflow.APIRef_cm_cloud_tenants_tenant-name_services_iapp.ashx" target="_blank" rel="noopener noreferrer">https://devcentral.f5.com/wiki/iWorkflow.APIRef_cm_cloud_tenants_tenant-name_services_iapp.ashx</a>
Usage:
    ./delete-error.py -u username -p password
import json
import httplib
from base64 import b64encode
import optparse
import sys
import socket
parser = optparse.OptionParser()
 debug option for args
parser.add_option(
    '-a',
    '--address',
    dest="address",
    default="127.0.0.1",
    action="store",
    help="address of remote device"
parser.add_option(
    '-d',
    '--debug',
    dest="debug",
    default=False,
    action="store_true",
    help="Print out arg values given"
parser.add_option(
    '-u',
    '--user',
    dest="remUser",
    default='admin',
    action="store",
    help="Remote user name"
parser.add_option(
    '-p',
    '--pass',
    dest="remPass",
    default='admin',
    action="store",
options, remainder = parser.parse_args()
 get auth token
def get_token(user, password, address, debug=False):
    conn = httplib.HTTPSConnection(address)
    cred = user + ":" + password
    userAndPass = b64encode(cred).decode("ascii")
    url = '/mgmt/shared/authn/login'
    post_data = '{"username":"' + user + '","password":"' + password + '"}'
    headers = {
        'Authorization': 'Basic %s' % userAndPass,
        'Content-Type': 'application/json'}
    try:
        conn.request("POST", url, post_data, headers=headers)
        r1 = conn.getresponse()
        if r1.status != 200:
            print r1.status, r1.reason
            sys.exit(0)
        data = r1.read()
    except socket.error, e:
        print e
        sys.exit(0)
    except:
        raise
    conn.close()
    data_dict = json.loads(data)
    token = data_dict['token']['token']
    return token
 GET
def get(address, url, auth_token, debug=False):
    headers = {
        'X-F5-Auth-Token': auth_token, 'Content-Type': 'application/json'}
    try:
        conn.request("GET", url, headers=headers)
            sys.exit(0)
        data = r1.read()
        print e
        sys.exit(0)
    except:
        raise
    conn.close()
    get_data = data_dict
    return get_data
 PUT
def put(address, url, auth_token, put_data, debug=False):
    headers = {
    try:
        conn.request("PUT", url, put_data, headers=headers)
            sys.exit(0)
        data = r1.read()
        print e
        sys.exit(0)
    except:
        raise
    conn.close()
    put_result = data_dict
    return put_result
 post
def post(address, url, auth_token, post_data, debug=False):
    headers = {
    try:
            sys.exit(0)
        data = r1.read()
        print e
        sys.exit(0)
    except:
        raise
    conn.close()
    post_result = data_dict
    return post_result
 PATCH
def patch(address, url, auth_token, patch_data, debug=False):
    headers = {
    try:
        conn.request("PATCH", url, patch_data, headers=headers)
            sys.exit(0)
        data = r1.read()
        print e
        sys.exit(0)
    except:
        raise
    conn.close()
    patch_result = data_dict
    return patch_result
def delete(address, url, auth_token, debug=False):
    headers = {
    try:
        conn.request("DELETE", url, headers=headers)
            sys.exit(0)
        data = r1.read()
        print e
        sys.exit(0)
    except:
        raise
    conn.close()
    return data
if __name__ == "__main__":
     setup vars
    user = options.remUser
    password = options.remPass
    address = options.address
    debug = options.debug
     print arg info in debug
    if options.debug:
        print "options dict: ", options, " remainder: ", remainder
     get auth token
    auth_token = get_token(user, password, address, debug)
    if options.debug:
        print "auth token is: ", auth_token
     GET list of placemnts in "status": "ERROR_IN_DELETION"
    url = '/mgmt/cm/cloud/tenants/services/placements/'
    get_placements = get(address, url, auth_token, debug)
    placements_list = get_placements['items']
    for p in placements_list:
        if p['status'] == 'ERROR_IN_DELETION':
            print "Placement ", p['appName'], " in status:"
            print "status ", p['status']
            print "For L4-L7 Service:"
            print p['tenantServiceInstance']['selfLink']
             doing a PUT on L4-L7 Service with the body of itself
             changes placement status to ERROR_IN_PLACEMENT
             then we can delete the L4-L7 Service
            url = p['tenantServiceInstance']['selfLink'][17:]
             GET service json for PUT body
            service = get(address, url, auth_token, debug)
             format of PUT body
            put_data = json.dumps(service, indent=4)
             Do PUT on the service to change placement status
            put_stat = put(
             delete service right after, seems to only work if done quickly
             I could not get to work by manually doing this with curl
             I do not know the reason for this
            print "Deleting ", p['appName'], "\n"
            delete_stat = delete(
