I have a long wait on a application configured on a bigip LTM 3900 v10.2.2. I captured the traffic on the bigip and there are a few things i see that seems strange…
On a common tcp.flow, there is about 10-30 seconds between two HTTP request. The previous ack before the delayed HTTP request doesn’t seems to be seen on wireshark… (the number of request and response is différent according to the stats on wireshark)
the server doesn’t send anything after the reply to the request (completed?). The response to the delayed request Is fine though.
Now i’m looking for help to troubleshoot this problem. There is no delay if we access the application directly. Is wireshark not the best tools to help me understand the delay? What can i do with BigIP profiles? (I use the standard TCP profile and the standard HTTP profile with caching disadled)
This morning I captured the traffic also on the server. There is the same number of request and response… Also, I can see many retransmission Client Side…
I have no irules involved on this virtual server. This is an http application runnin on port 80 built with the template “HTTP application” where i changed a few things on the HTTP profile:
Add x-forwarded-for HTTP-header
No Caching
The tcpdump syntax are :
Server Side (Linux Redhat Server): tcpdump -B 4096 -s0 -ni eth0:nnn ‘port 16073 or icmp’ -w
On the BigIP : tcpdump -s0 -ni 0.0:nnn ‘(host 129.195.246.121 and port 80) or ((host 129.195.112.65 or host 129.195.112.77) and port 16073) or icmp’ -w
Client Side: use of wireshark on windows - no filter
It seems no traffic is lost, but on the client side, i see many retransmission. I tried a few changed on the tcp profile, but nothing thing to help.
Great, thank you. Not sure what the :nnn is all about but otherwise looks good.
If you only see retransmissions on the client side using Wireshark I will assume these are spurious and probably related to NIC offload or something similar.
Can you be more specific about when the delay occurs please? The 10-30s delay is between two requests? Does that mean the client is waiting for a response to request 1 before sending request 2?
I’m not an expert in capture explanation, but it seems the delay is between an ack to a HTTP response (200 OK) and an http request. So the client doesn’t seems to wait for a response…
I tested with chrome, ie and firefox and the result is the same.
After a few more try and some difficulty to read the tcpdump capture from the BigIP, it seems only the response received on the client capture has some delay.
So, on the BigIP and the server, the request and the response are fine, but on the client, i see a delay of 10-30s.
Also, on the bigip, the capture is very difficult to read as some part seems to be missing. On some capture, wireshark doesn’t understand or translate the HTTP response (200 OK), but if i look at the multiple TCP packet, i can see the “200 OK” anyway…
Depending on how much content is downloaded and the bandwidth available between the F5 and the client, there will be a delay in seeing the HTTP response on the client. It may take 10-30 seconds for the response to get to the client, so the client will see a 10-30 second delay.
If you are using a port other than 80 for HTTP traffic, Wireshark will not interpret the traffic as HTTP and thus will not show HTTP request/response. In Wireshark you can go to Edit/Preferences/Protocols, then select HTTP and add what ever ports you are using for HTTP traffic. I am assuming you are using 16073 since this is one of the ports you are capturing traffic on.
As i told in my messages, the content is pretty small (17KB for example). On chrome or Firefox, i can see the transfer of the small packet taking a long time. If i access the application directly, it goes well.
About wireshark, the client side is using port 80. also, wireshark seems to decode well the traffic on port 16073 as http, but it seems some packet are not complete.
17KB would be more than one packet, more like 10 or 11. I’m still rather confused about when the delay occurs, from a TCP perspective. Rather than go round in circles with that lets just do a general check.
Firstly, can you confirm what TCP profiles you are using on your Virtual Server and whether they are set to default settings or not. Also confirm that Nagle is turned off.
Secondly can you check the MTU configured on the VLANs involved and let us know.
Thirdly, can you do a ping from the client to the Virtual Server using a 1500 payload size. In Windows this would be
ping -l 1500 x.x.x.x
. If that doesn’t work, keep dropping the size down by 20 till it does. Obviously, note if the time is excessive.
If would also be good to do the same from the server to the F5 if possible?
HTTP request from the client to the F5 takes “no time at all.”
HTTP request is forwarded from F5 the to the server in “not time at all.”
HTTP response from server to F5 takes “no time at all.”
HTTP response from the F5 to the client take 10-20 seconds.
If this is correct, what I would do is examine the packet capture from the F5 showing the interaction between the F5 and the client and the packet capture from the client. Look at the time stamps on each individual packet.
I looked many time the capture form each side of the F5, and it seems that :
The request are delivered in no time and are fine (from the client to the f5 and from the f5 to the server.
The response seems to go well from the server to the f5 (i don’t see any packet from this side during the wait - neither on the f5 nor the server capture)
There are some retransmission from the client during the transfer… each retransmission take 1 more second. What can i do to explain those retransmission and find a solution? I tried with différents internet browser but the problem is still the same.
Which browser being used should not make a difference.
You would need to run a packet capture on each device (both the ingress and egress side of that device) that sits between the F5 and the client to see where the packet might be getting dropped.
I would start with the device closest to the F5. Each device includes all routers/switches/firewalls. Anything that could possibly drop/delay a packet.
As it is difficult to run packet capture on our router as it is very critical, i continued to do some test in our network. So, i figured that anywhere on the network, if :
my computer is connected with 100Mb/s, the problem appear
my computer is connected with 1000Mb/s, there is no problem
So my question is : how the speed negociated with my computer can change the behaviour of the application on such a small need of trafic…?
Are you doing anything on your computer to change the speed you are connecting at? What type of switch is your computer connected too?
Double check your duplex. If the switch port is doing full duplex and your computer is doing half, you will get increased response time.
Earlier you stated that if you bypassed the F5 that you got good response time. If you connect at 100 Mbps and bypass the F5 is response time fast or slow?
I don’t do anything to change the speed and duplex on my computer. Both the switchs and computers are configured with autonegociation. The duplex is always Full on both switch and computer.
I tried on different switch type : - Avaya ERS 4550T PWR (users ports are 100Mb/s and there are 2 x 1Gb/s ports). I tried both - Avaya ERS 4850 GTS (all ports are 1Gb/s) - Avaya ERS 4548 (all ports are 1Gb/s) - Avaya ERS 8800 (Router - i used a copper Gbic to run the test - 1Gb/s only)
The result are always the same anywhere on the network : - with 1Gb/s Full duplex : The application works fine - with 100Mb/s Full duplex : the application suffers of delay (10-30s)
Also, if i bypass the F5 and use the real IP of the server, everything work fine.
Run tcpdump to capture output stream from F5 to Client
Run packet capture on client to capture stream from F5
Setup a port mirror on the Avaya ERS 4550 uplink.
Access the application
Look at all of the packet captures and see where the problem is.
Since you have a ERS 4550 PWR I am assuming that you have VOIP. Do you also have QOS setup? Is the 4550 getting flooded with too much data and dropping things?
I already ran some capture some capture like you said (see the command on the second answer). What i see is some missing packet, some duplicate ACK and some retransmission. At a time, there is 1 second between the retransmission and it represent the delay i talk about.
Also, this morning, i tried an exact same configuration on a VM installation with the same BiGIP version and the same application, and everything work fine.
Is this possible the BigIP ltm3900 have some communication issue? (it is attached with 2 x 1Gb J45 with LACP)
