Default route for Route Domain
Can anyone tell me why I cannot add a default route for a non-default route domain on my 10.0.1 HF2 box?
route domain 1 {
description “Front_End”
vlans {
WF_Front_Ext
WF_Front_Int
self 10.0.41.251%1 {
netmask 255.255.255.0
vlan WF_Front_Ext
allow default
self 10.0.42.251%1 {
vlan WF_Front_Int
allow default
Trying to add a default route as:
route any%1 {
gateway 10.0.41.1
Results in an error “01070330:3: Static route gateway 10.0.41.1 is not directly connected via an interface.”
It does allow me to add the route as:
route any%1 {
gateway 10.0.41.1%1
But it doesn’t appear to work. The documentation on page 10-13 of the “TMOS Management Guide” says that you *don’t* need to append “%X” prefix when specifying the gateway for a default route.
Clearly 10.0.41.1 *is* directly connected out of my “WF_Front_Ext” interface vlan…
Any help appreciated!
Thanks,
Ellis
I’m running into the same issue. Any suggestion?
thanks,
QH
Sorry, no!
In the end I decided not to use route domains but instead to use VLAN group’s.
Although this appears to of created another issue with the stand-by device…but that’s another story! :slight_smile:
Good luck.
Has anyone risen above this problem?
I have always had to use the % route domain specification on the back of the gateway address when adding a default route for a route domain.
Are you meaning that you select ‘route’ rather than ‘gateway’ and then configure the route with the %id after it? Also choosing the relevant route domain in the drop down.
Thats what i’ve done.
Having issues with arp not working. If I put static arp entries in it works for me.
Using administrative partitions in combination with my route domain sorted my arp issue.
Posted By EllisD on 10/14/2009 06:06 AM:
route any%1 {
gateway 10.0.41.1
route any%1 {
gateway 10.0.41.1%1
_______
Looking at “Adding a standard route for a route domain” section of above document: “If the route you are adding pertains to a partition default route domain, you do not need to indicate the relevant route domain in the route’s IP addresses (using the %ID notation). If the route you are adding pertains to a route domain other than the partition default route domain, you must include the relevant route domain ID.”
So, the way I read it is if the default route domain, is specified within partition definition, using “partition name default rd id”, then any route you define in this partition without %ID will apply to that route domain.
However, since there can be more than one route domain within a partition to define route for those which isn’t default route domain, you’ll need to specify %ID.
And then we check and test to ping IP Gateway 192.168.208.254 and the result host unreachable you did ping from bigip, didn’t you? what command did you use? was it “ping 192.168.208.254%2”?
Hi Nitass,
Yes I did, I ping from bigip and use command ping 192.168.208.254%2
Thanks.
Best regards,
Taufik
Can you check the default route you created is 0.0.0.0%2
Thanks,
Sriram
Thanks,
Sriram
Hello
I am using Icontrol with 10.2 Version.
I created an RD (ID 25) on a given partition.
Do you know if it is possible to set this RD as default inside this partition via the Icontrol API.
If yes what is the method with 10.2 Version ?
Thanks for your help
Laurent
Check your self/float IP if you have the correct netmask. I run into the same issue today and sure enough, my vlan is setup to be /23 instead of /24.
What would happen if you tried “rdexec 2 ping 192.168.208.254” ?
