Does anyone have a list of services running and responding on the MGMT interface by default in 11.6? I haven’t been able to find any official documentation. If it doesn’t exist are there any services other than SSH and HTTPS?
The following shows the list of services: 404 Page not found | BIG-IP Documentation
By default I think only https, ssh and snmp are listening for remote connections. I believe there is a daemon listening for syncing and other purposes depending on what services you start. ‘netstat -an | grep LISTEN’ will show the various listen ports and you can use “lsof -i :port” to see what service that port is bound too.
