Default APM built-in report
Hello,
In 11.5.x versions when I clicked on Access Policy ›› Reports : View Reports the “All sessions” report was automatically opened. Now in version 12.x, when I click on the equivalent (Access Policy ›› Event logs) no report is launched.
How can I get back to the old behavior or configure this?
Thanks in advance.
Hi Fab,
Are you using the admin user or are you using a different user when logging into the Admin UI? If so you are probably running into BZ 576748.
To workaround this you can run the report you want to have be the default “All Sessions” and in the top menu bar of the report structure is “Set to default report”. Click this and you should be set going forward.
-Seth
