DB variable Sync Issue between Blades of Same chassis
Hi All,
I have following DB variable configured on the Primary Blade of my chassis which is not sync to Secondary Blade in Slot 2.
F51:/S1-green-P:Active:In Sync] ~ tmsh list sys db platform.diskmonitor.limitwarn.var
sys db platform.diskmonitor.limitwarn.var {
value "20"
F51\1:/S1-green-P:Active:In Sync] ~ ssh slot2
Last login: Tue Jul 31 12:12:37 2018 from 127.3.0.1
F51:/S2-green-S:Active:In Sync] config tmsh list sys db platform.diskmonitor.limitwarn.var
value "40"
Is this normal that DB variables are not Synced between Blades of same chassis. Usually all the configuration should be Synced automatically from Primary to Secondary blade.
Appreciate your response.
Thank you ! Sani
