Hi - want to do a check on F5
when ssl handshake - extract OU from certificate and validate it against client IP .
so i created a data group with address and value
Question how would i match the pair of ip and ou as address and value
ltm data-group internal ip_allow {
records {
10.10.10.0/24 {
data Prod
20.20.20.0/24 {
data Staff
type ip
@awan_m I believe the following will work for you but I’m not 100% positive because I can’t lab it. This is assuming you intend to send it to a specific pool but if not you can change the action in the if statement matching TEMP_OU to whatever action you would like.
when CLIENTSSL_CLIENTCERT priority 500 {
set cert_subject [X509::subject [SSL::cert 0]]
# release any stored data just in case
HTTP::release
# if there is still no cert after the SSL renegotiation kill the connection by sending a reset back to the client
if { [SSL::cert count] < 1 } {
reject
when HTTP_REQUEST priority 500 {
if { [class --match [getfield [IP::client_addr] "%" 1] equals ip_allow] } {
set TEMP_OU [class --match -value [getfield [IP::client_addr] "%" 1] equals ip_allow]
if { ${cert_subject} == ${TEMP_OU} } {
pool <pool_name>
reject
you need to do in 2 steps:
1. determine which address range that the client ip address belongs to (using the above IP:addr …; loop the address ranges until matching one)
2. check whether the ou matches the address range (using the data group)
To match the pair of IP and OU, use an iRule during the SSL handshake. Extract the client’s IP and the “OU” from the certificate. Then, match the IP in your data group and check if the stored value (OU) matches:
Extract the client IP and OU.
Check if the IP exists in your data group.
Compare the stored value (OU) with the extracted OU.
